Project Cars 2  Topic is solved solved with post #21712
Project Cars 2
Postby billo2404 » Fri 22. Sep 2017, 16:12
Hi guys, someone has already tried to configure this new game?
billo2404
Images: 72
Has thanked: 7 times
Re: Project Cars 2  Topic is solved
Postby billo2404 » Sat 23. Sep 2017, 09:20
I reply:
It works by treating it just as chapter 1 :D :D :D
billo2404
Images: 72
Re: Project Cars 2
Postby titomaky » Sun 24. Sep 2017, 13:03
Hello friend, could you tell us the steps to follow besides indicating which is the plugin used for pcars2. a greeting :roll: :cry
https://www.youtube.com/watch?v=7laEHbTNcIA
titomaky
Re: Project Cars 2
Postby billo2404 » Fri 6. Oct 2017, 13:54
visto che sei spagnolo ti scrivo in italiano e dovrebbe essere più semplice la traduzione:
Innanzitutto scusa ma non mi arrivano le notifiche e non avevo visto la tua richiesta.
Il plugin da utilizzare è il vecchio di projectcars 1
Quando configuri il gico devi selezionare l'exe di exctractor altrimenti dopo un po' si blocca come il vecchio capitolo.
Nelle opzioni del gioco per la comunicazione con le app esterne devi selezionare:
-----projectcars 1
-----no
-----projectcars1
since you're writing you in Italian and Spanish should be easier translation:
First excuse but I receive notifications and I had not seen your request.
The plugin to use is the old Project CARS 1
When setting up the game you must select the exe otherwise exctractor after a while 'crashes like the old chapter.
In the game options for communication with external apps you have to select:
-----projectcars 1
-----no
-----projectcars1
billo2404
Images: 72
Re: Project Cars 2
Postby vicpopo » Thu 2. Nov 2017, 12:05
Hi Billo2404,
Tested this morning and I confirm it works perfectly like you describe .
Nothing to do Xsim side , just like you wrote the setup into projectcars 2 !
Many thanks for these usefull information.
Greetings
Re: Project Cars 2
Postby xmotionbr » Thu 2. Nov 2017, 16:22
HI Billo2404
I followed your instructions and projectcars 2 is not working
can you please post the images of your extractor and game configuration
Thank you in advance
xmotionbr
Re: Project Cars 2
Postby vicpopo » Thu 2. Nov 2017, 19:17
Hi xmotionbr,
Maybe a silly question .Did you have a configuration working with xsim with pcars 1 ?
You need to have this before .
Re: Project Cars 2
Postby xmotionbr » Tue 7. Nov 2017, 23:53
Hi vicpopo
Project cars 2 working
Thank you very much!
xmotionbr
Re: Project Cars 2
Postby robertogo » Tue 20. Mar 2018, 13:39
wich version work?
thanks.
robertogo
Images: 3
Re: Project Cars 2
Postby marcocampa » Mon 5. Nov 2018, 13:23
billo2404 wrote:visto che sei spagnolo ti scrivo in italiano e dovrebbe essere più semplice la traduzione:
-----projectcars 1
-----no
-----projectcars1
-----projectcars 1
-----no
-----projectcars1
Non ho capito cosa vuol dire selezionare l’exe di exctractor perché mi funziona tutto ma dopo 20 minuti non arrivano più i dati grazie in anticipo
marcocampa
