Flyinside x-plane11 plugin?
Postby toofast » Tue 29. Aug 2017, 03:00
Hi guys!
I'm very happy because I finished my 2dof racing seat. And it's already working with most of my simulators, but I have a problem with X-plane11.
I have managed to work with the X-plane V.4 plugin but only version 2d.
I would like to be able to use it with my oculus rift, for that you have to launch it through a program called flyinside xp. It installs itself in the same folder as the x-plane11.
I tried to create a profile just like I did for the x-plane to work, when I press the play button, the simulator starts but the converter does not connect to the extractor.
The button does not go gray or the start button on the converter turns red. Although the x-plane plugin does read game telemetry when flying.
I've read a lot in the threads and I've done what it takes to run, find the folders manually, give admin rights, but it seems like something escapes me.
I need help from someone wiser than me.
Is it possible to do some modification to the plugin or missing some new dll in the plugins folder for the extractor to detect it?
Thank you very much in advance.
Thanks to Sirnoname for making possible the dream of us all.
toofast
