f1 2016 codemster problem vertical force
Postby spyderwash » Wed 2. Nov 2016, 23:04
I ask confirmation to those who own this game, I saw that the vertical force 25 effect sends data only peaks with values outside the norm
spyderwash
Re: f1 2016 codemster problem vertical force
Postby sirnoname » Thu 3. Nov 2016, 14:40
Vertical are peaks.
Postby spyderwash » Thu 3. Nov 2016, 17:18
only a peak in value does not modulate
spyderwash
Postby marcogiulini » Fri 4. Nov 2016, 16:48
Confermo vertical force bloccata ad un valore altissimo, nessuna variazione durante il gioco.
marcogiulini
Postby sirnoname » Fri 4. Nov 2016, 17:22
You mean 9G earth gravity?
Postby marcogiulini » Sat 5. Nov 2016, 11:48
i see vertical force blocked to -2147483648
marcogiulini
Postby sirnoname » Sat 5. Nov 2016, 12:39
Do you use the latest plugin? F2015 post.
Postby spyderwash » Sat 5. Nov 2016, 13:27
it is with the new plugin f1 2015
spyderwash
Postby marcogiulini » Mon 14. Nov 2016, 20:34
X-sim after one minute stop work.
marcogiulini
Postby sirnoname » Fri 2. Dec 2016, 23:40
No Problems wit F1 2016 for 5 Minutes. Seems you have other problems in the configuration.
Users browsing this forum: No registered users and 52 guests
