Dirt Rally (Extractor) Problem  Topic is solved solved with post #19971
Postby Argon » Wed 7. Sep 2016, 20:34
Hello,
my name is Stefan i want to upgrade my Rig for Dirt Rally with a Buttkicker. Until now i used the ingame sound, but this solution is not the best. Over another Racing
Forum i went here. My Problem: The Converter gets no Data from the Extractor, only wheelmovement (G25).
I Start completly from beginning:
Install X-sim ;)
- Start extractor with Admin rights
- Add the game, the auto search doesnt Work for Dirt Rally so i have to manuall add it:
- drt.exe
- as Plugin i took "Codemaster"
- Callparameter: steam://rungameid/310560
Then i Click on right side on Drt.exe and a popup asks me:
"Codemaster, There is a official game plugin detected for this game executable.Do you like to activate/change this Plugin in the motion driver dialog?"
-> YES
Automatically Setup?
-> YES
as input i use my G25, than i create a Profile.
Changes in Dirt Rally XML:
I have two XML-files, dont know why there are two of them.
D:\Program Files (x86)\Steam\steamapps\common\DiRT Rally\system
C:\Users\Argon\Documents\My Games\DiRT Rally\hardwaresettings
Both are identical and i added/changed:
<motion_platform>
<dbox enabled="true" />
<udp enabled="true" extradata="1" ip="127.0.0.1" port="20777" delay="1" />
<fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
</motion_platform>
<controls neutralTimeToShift="0.25" />
</hardware_settings_config>
Now we are Ready for a first Start, in the Extractor i Hit "Play Game" and a woman says "Game detected"
When i drive i change to Converter and start, and look at the inputs, but the values for speed/gear arent changing.
the window "outsimDirt2" is always "Game Paused" and the values are all zero.
the Window Says: Send to IP: 127.0.0.1 port: 20777
and Listening Port: 20778
I dont know where i have to search my error. What Means Listening port? Do i have the Right Plugin? A lot of Codemaster Games use LiveforSpeed, but with this Plugin it also failed. (also changed the ports). Do i have the Plugin manually?
So many Questions :), I hope someone can Help or can give me a hint where i have to search.
Greetings from Bavaria
41834182
Argon
Images: 2
Re: Dirt Rally (Extractor) Problem  Topic is solved
Postby Argon » Thu 8. Sep 2016, 08:57
After 8 Hours sleep and look from the distance i got it working.
Solution for all Dirt Rally Player: You have to change the Port in the XML File to 20778.
<motion_platform>
<udp enabled="true" extradata="1" ip="127.0.0.1" port="20778" delay="1" />
</motion_platform>
Just that easy :lol:
Maybe, in the "Supported Games" section we can add Dirt Rally with the Codemasters Plugin and the Port 20778 to add. Would be nice ;)
Wish you all a good day,
Have fun!
Argon
Images: 2
Postby Lynxt » Mon 31. Oct 2016, 20:37
Thanks for the information i just solved extractor problem for my bass shaker setup a week ago (Project cars game)
in these days ill setup them for dirt rally.. I'm planning two steps to finalize my setup a handbrake and Htc vive..
Lynxt
Postby sirnoname » Mon 31. Oct 2016, 21:00
20778 is only if you accidential enable the port forwarding/multiplier in the plugin (Task bar). You should set it back to 20777.
