Dirt Rally & X-Sim Not Working  Topic is solved solved with post #18103
Postby KyriakosCY » Sat 21. Nov 2015, 17:15
A few months on and I am still not able to get this working even though it was working flawlessly for months before the XML changes were implemented... I have since formatted my PC and installed windows 10 and the issue still persists.. The outsimdirt2 stays paused... I have everything setup and the converter and extractor are successfully communicating with each other, when I start the game my Arduino dash recognises that and displays the check digit yet the outsimdirt2 stays paused. I have added the line of code to the xml in both documents and the game install folder. I have tried the updated plugin I found here on the forum and still nothing.
Here is my plugin code to detect the game
Code: Select all
// X-Sim 3 game configuration script
title: DiRTRally script
games: DiRT Rally (steam)
search_executable: drt.exe
game_parameter: steam://rungameid/310560
unicode: no
mustdir1: steam
notdir1: demo
plugin: Dirt2plugin.dll
Here is my XML
Code: Select all
<?xml version="1.0" encoding="UTF-8" ?>
<hardware_settings_config version="9" deviceId="0x17C8">
   <cpu>
      <threadStrategy workerMapFile="system/workerMap4Core.xml" forceFeedbackProcessor="3" dvdStorageProcessor="3" dataSetMonitorProcessor="1" renderProcessor="0" updateProcessor="2" fileStreamProcessor="3" />
   </cpu>
   <audio_card>
      <dynamic_range value="high" />
      <eq value="flat" />
      <voice_chat enabled="true" />
      <push_to_talk enabled="true" />
   </audio_card>
   <graphics_card rating="4" firstBoot="true">
      <directx forcedx10="false" />
      <eyefinity force="" osd="" />
      <stereo enabled="false" separation="0.015" convergence="0.5" />
      <resolution width="1024" height="768" aspect="auto" fullscreen="false" vsync="1" multisampling="8xmsaa">
         <refreshRate rate="59" />
      </resolution>
      <gamma level="0.8" />
   </graphics_card>
   <shadows enabled="true" size="3072" maskQuality="2" particles="true" />
   <advanced_fog enabled="true" />
   <particles enabled="true" wind="true" dynamicRes="false" lowResScalar="2" nearFadeBias="0" />
   <weather quality="1" />
   <crowd enabled="true" detail="4" />
   <cloth enabled="true" tessellation="true" />
   <groundcover mode="ultra" clutter="true" />
   <objects lod="1.02" maxlod="0" stones="true" />
   <trees lod="1.2" maxlod="0" meshes="true" meshes_in_all_passes="false" />
   <vehicles characterQuality="4" lodQuality="3" />
   <track lod="1.0" />
   <envmap faces="6" size="1024" drawallobjects="true" scaleminsize="0.75" mindistance="150.0" />
   <water update="true" detail="3" scale="2" drawallobjects="true" tessellation="true" />
   <mirrors enabled="true" width="768" height="256" car_maxlod="1" car_culldist="300.0" />
   <skidmarks enabled="true" />
   <dynamic_ambient_occ enabled="true" quality="4" />
   <dynamic_ambient_occ_soft enabled="true" />
   <night_lighting volumes="true" lights="0" shadows="true" onlyHeadlights="false" shadowSize="2048" />
   <textures resolution="3" />
   <shaders quality="2" low_quality="false" />
   <anisotropic min="4" max="16" />
   <physics environmentalDamage="true" vehicleDamage="true" />
   <input device_type="auto" />
   <screenshotMode enabled="false" />
   <aoit enabled="false" />
   <avsm enabled="true" />
   <oculus enabled="true" headMovement="true" chromatic="true" timeWarp="true" vignette="true" overdrive="true" convergence="1.0" verticalOrientation="0.66" />
   <motion_platform>
      <dbox enabled="true" />
      <udp enabled="true" extradata="2" ip="127.0.0.1" port="20777" delay="1" />
      <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
   </motion_platform>
   <controls neutralTimeToShift="0.25" />
</hardware_settings_config>
My Motion Driver Setup
Here is an Image of all Software Running Together
http://postimg.org/image/x0lqszwl5/full/
Please can somebody help out? Any help is greatly appreciated! Thanks :)
KyriakosCY
Re: Dirt Rally & X-Sim Not Working  Topic is solved
Postby sirnoname » Sat 21. Nov 2015, 19:08
Please use the forum search option, same for F1 2015.
Postby tintao » Sat 9. Jan 2016, 17:20
up
tintao
Postby sirnoname » Sat 9. Jan 2016, 21:35
plz read!
