f1 2015  Topic is solved solved with post #20412
f1 2015
Postby spyderwash » Sun 19. Jul 2015, 18:09
Hello everyone, I just received f1 2015 but with x-sim ninth receive data I also changed the file-setting hardware-config
<motion>
<dbox enabled = "false" />
<udp enabled = "true" ip = "127.0.0.1" port = "20777" />
</ motion>
but I still do not have movements
what changes should I do?
thanks
spyderwash
Re: f1 2015
Postby graw78 » Mon 20. Jul 2015, 08:09
Try dbox true
:mrgreen:
graw78
Re: f1 2015
Postby adrianovrm » Mon 20. Jul 2015, 15:02
Excuse me, What is dbox true ?
adrianovrm
Re: f1 2015
Postby spyderwash » Mon 20. Jul 2015, 18:22
dbox enabled but still no signal does not take a new plugin for this game?
<motion>
<dbox enabled="true" />
<udp enabled="true" ip="127.0.0.1" port="20777" />
</motion>
spyderwash
Re: f1 2015
Postby sirnoname » Tue 21. Jul 2015, 08:58
File location?
Extradata=?
Screenshot of codemaster plugin hidden in Taskbar.
Re: f1 2015
Postby graw78 » Tue 21. Jul 2015, 20:11
Post screenshot andò remember to mod 2 file.
1 in Codemasters location andò other in savefile location
I'm sure Sirnoname help you after You'll post screenshots
I've not try this game but if i van help you i'm happy ;)
Best regards Simone
graw78
Re: f1 2015
Postby spyderwash » Tue 21. Jul 2015, 22:39
I have found documents in a single file to be edited
\ documents FormulaOne2015 hardwaresettings My Games \ hardware_settings_config.xml
no longer preseni ExtraData
spyderwash
Re: f1 2015
Postby sirnoname » Tue 21. Jul 2015, 22:42
Then try life for speed plugin eith fitting port.
Re: f1 2015
Postby spyderwash » Wed 22. Jul 2015, 18:28
I also tried this setup with plug lfs
but no result
<?xml version="1.0" encoding="UTF-8" ?>
<hardware_settings_config version="37" deviceId="0x13C0">
<cpu cores="4" hyperThreading="true" hyperThreadingProcessorStride="1" />
<graphics_card rating="4">
<resolution width="5744" height="1042" fullscreen="false" vsync="false">
<refreshRate rate="0" />
<windowPosition x="0" y="0" />
</resolution>
</graphics_card>
<motion>
<udp enabled="true" ip="127.0.0.1" port="4123" />
</motion>
<antialiasing smaa="true" taa="true" />
<ssao enabled="true" quality="4" />
<led_display fanatecNativeSupport="true" sliProNativeSupport="false" />
<anisotropic_filter level="16" />
<lighting quality="2" />
<postprocess motionBlur="true" godRays="true" depthOfField="true" lensStreak="true" lensFlare="true" bloom="true" rainBeads="true" />
<shadows enabled="true" skyShadowMapSize="2048" skyShadowCascadeCount="4" skyShadowLowLod="false" worldShadowMapSize="2048" nightShadowMapSize="2048" nightShadowCharacterCast="true" nightShadowSourceCount="4" sampling="2" />
<smoke_shadows enabled="true" mapSize="512" opacity="1.0" envOpacity="0.45" updateRate="2" />
<advanced_smoke_shadows enabled="false" />
<particles enabled="true" distanceScale="1.0" globalsort="true" />
<crowd billboardPercentage="50" lod0Distance="4" lod1Distance="10" lod2Distance="25" lod3Distance="70" billboardDistance="700" finDistance="1000" lod0Quantity="5" lod1Quantity="20" lod2Quantity="50" lod3Quantity="300" billboardQuantity="22000" finQuantity="5000" propQuantity="50" />
<characters mipOffset="0" />
<vehicles mipOffset="0" />
<environment mipOffset="0" />
<vehicle_reflections envMapScale="2.0" envMapUpdateMode="alternate" envMapRenderMode="carsAndCharacters" mirrorMapScale="2.0" mirrorsUpdateMode="alternate" mirrorsRenderMode="carsAndCharacters" treesInMirrors="true" />
<weather_effects rainSplashes="true" rainSheets="true" rainBeads="true" trackHeatHaze="true" planarReflectionsEnabled="true" planarReflectionsRTScale="1.0" planarReflectionsMipTailBlur="true" />
<ground_cover enabled="true" grassFlattening="true" drawDistance="120.0" />
<skidmarks enabled="true" parallax="true" />
<skidmarks_blending enabled="false" />
</hardware_settings_config>
spyderwash
Re: f1 2015
Postby sirnoname » Thu 23. Jul 2015, 00:53
Dbox disabled?
