Problem with x-sim plugins on all games
Postby billo2404 » Sat 1. Feb 2014, 16:22
Hello to all. I found that as soon as I install x-sim and then its plugins have problems on almost all the games I have:
Rfactor not part
Ratr2 not part
Grid2 side but hangs at the end of any race at the finish line.
Dirt3 seems to work well but I have not thoroughly tested.
To redo work the games I go to remove the x-sim plugin manually and then everything is ok, but so obviously I can not use the simulator.
Poets help me?
My setup is:
Win 7 64bit
5870 2GB DDR5 graphics card Eyefinity6
intel quad 6600
billo2404
Images: 72
Has thanked: 7 times
Re: Problem with x-sim plugins on all games
Postby micma80 » Sat 1. Feb 2014, 20:45
Hai impostato correttamente Extractor per il relativo gioco che vuoi utilizzare?
You have successfully set Extractor for its game you want to use?
micma80
micma80
Been thanked: 5 times
