Re: Assetto Corsa
Postby Fahim » Wed 11. Dec 2013, 23:21
1)I found out what the problem is. I have to add ANOTHER Line for Longitudinal movement then it works.
2)BUT this stops Lateral from working now!
3)Then I add another line for lateral, then longitudinal stops working. Back and fourth
4)It only lets me have either left/right movement or forward/back movement. Not both together.
I have done search from the forum but no topics to find information from. Regards
Fahim
Re: Assetto Corsa
Postby sirnoname » Thu 12. Dec 2013, 00:45
Re: Assetto Corsa
Postby Fahim » Thu 12. Dec 2013, 20:59
I used to the search button to find posts with "no longitudinal movement"
But thanks. Your a legend. The car's running.
Fahim
Re: Assetto Corsa
Postby caiubbo84 » Sun 15. Dec 2013, 11:42
Fahim wrote:I used to the search button to find posts with "no longitudinal movement"
Good morning,
The problem is that in the tab of the effect that you add, on the end of it you need to select add this result and this for every effect in the axis ;)
caiubbo84
Images: 15
Re: Assetto Corsa
Postby WowaDriver » Tue 8. Apr 2014, 20:32
Hi guys,
i have a start problem with assetto corsa and x-sim extractor. I followed all steps from the video tutorial.
Then i started the game and the play game button get the grey color for 2-3 seconds. After that the game
started normaly, but the extractor lost the connection to the game, because the play game button was getting
again blue.
My Assetto Corsa version: 0.14.329.3695
What is the problem??
Thanks for help!
WowaDriver
Images: 108
Assetto Corsa
Postby prodigy » Tue 8. Apr 2014, 23:59
There has been a lot of updates to the game. Last update reported few posts back was 0.3.1 and now the latest update is 0.8.2, maybe something changed in between them and the plugin doesn't work as it should.
But maybe something else is bothering you. Are you using some other tools with AC, fraps, radeonpro or something like this? Try disabling Steam Overlay option too..
Re: Assetto Corsa
Postby WowaDriver » Wed 9. Apr 2014, 19:19
// Edit !!
PROBLEM DONE !!!
Big thx to yokoyoko, i did forget to add the call parameter ... steam://rungameid/244210 by the game wizard... :oops:
See you soon
WowaDriver
Images: 108
Re: Assetto Corsa
Postby gabry1090 » Tue 24. Jun 2014, 00:54
hi guys, i've tried everything possible, but since update 0.9.0.2 the plugin is not working, no movement at all, no output :( please let me know, thanks!!
gabry1090
Re: Assetto Corsa
Postby jomaho » Thu 26. Jun 2014, 22:44
Same here. No motion since update .20 Converter showing movement in Input and Math plugins but no actual output movement. Think Kunos/AC has changed something in shared memory.
jomaho
Re: Assetto Corsa
Postby spyderwash » Mon 30. Jun 2014, 22:25
Hello everyone, I confirm that assetto corsa after last update does not work someone has a solution?
thanks
spyderwash
