Here you can talk about creating profiles, discuss your profile settings and share problems with games and plugins. Please note that you first have to read the the fitting game section in the manual!
I watched your video with assetto corsa , your simulator is realy fantastic and seems to be very very realistic. Congratulations !! I know also that your xsim profile is awesome .
Where lies the problem? I've tried to add it manually, copying wizard script from pCars and edited with AssettoCorsa details, but the error when starting game says it can't initialize Steam.
Is it something that Sirnoname can fix, or do we need to wait for developers of AC to change something in output?
prodigy wrote:Where lies the problem? I've tried to add it manually, copying wizard script from pCars and edited with AssettoCorsa details, but the error when starting game says it can't initialize Steam.
we are working at this moment on it.... we will change from UDP telemerty to shared memory. Roll pitch and yaw will be available too. If it will work
If something is ready I will post it here - hope this evening.
this you will have to insert into the plugin folder of x-sim - and replace it with the old one!
After you have done this start the extractor and do an autoscan with the "game wizard". Please report if the autoscan works and you can start the game via the play game button
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Option 2: (only if the prefered solution above does not work for you!) Please disable the autodetection of x-sim - the "X" in the taskbar should be red!
and replace it with the old one in the x-sim plugin-folder.
After start the extractor and add the game manually with the game wizard. this should look like this:
The AssettoCorsa.exe is located in your steam directory - Steam\SteamApps\common\assettocorsa\AssettoCorsa.exe Choose the AssettoCor plugin Type the call parameter ---> steam://rungameid/244210
Now you could start the game with the play game button.
Have fun!
Further infos: - Speed, gear, effect 25,26,27 - work like expected - Roll and pitch don't - can't figure out atm what kunos did there... Perhaps you can help. Pitch has an negative offset. Roll seems to be related to the "dynamic" roll of the car but is not really track related?! - Yaw (effect 29) is 360°yaw - Yaw slip (34) is working like in Pcars f.e. - you will have to find the minimum value where the car looses traction and set this. ---> we will need to ask in the Assetto Corsa forum for some infos on roll and pitch!
I actually used half of first option and half of second
I've put new wizard script and plugin but added the game manually and call parameter. I was reading your tutorial too fast, didn't noticed options, just files to download
