New Dirt Rally Available!
Re: New Dirt Rally Available!
Postby KyriakosCY » Sun 18. Oct 2015, 11:12
I am having problems with Dirt Rally. Before the updates in July everything was working perfectly, but since they changed "motion" to "udp" nothing is working. I have downloaded the updated outsim plugin and used various different strings in the hardware xml but nothing works, the outsim is stuck on game paused. Can anybody help me out with this pls..? Thanks :)
KyriakosCY
Postby yosko » Sun 18. Oct 2015, 23:00
Hi it works well with codemasters plugin for dirt games. In the begining of this topic is described.
I play every day and there was problems in begining of September's but for about 2 weeks.
Scottlolo » Sat 2. May 2015, 20:00
DIRT RALLY
Plugin DIRT2
motion enabled="true" ip="127.0.0.1" port="20777" delay="1" extradata="1"
good work ,no crash
scottlolo 15 2 Thu 14. Feb 2013, 22:50 france 0 time 0 time
yosko
Postby KyriakosCY » Mon 19. Oct 2015, 10:22
Hi, thanks for the reply. I have also been playing since it was released in April but the "motion enabled" string in the hardware settings xml you attached no longer works as it has been changed by Codemasters. This is what was used when the game first came out but since the July/August updates this no longer works for me...
KyriakosCY
Postby sirnoname » Mon 19. Oct 2015, 19:41
no problem with pause here.
Postby KyriakosCY » Mon 19. Oct 2015, 21:01
sirnoname wrote:no problem with pause here.
I have been trying everything possible for weeks. Any chance you could do a quick re-cap of what you are doing including your xml string and plugin so I can try it pls.
Much appreciated..! :)
KyriakosCY
Postby KyriakosCY » Fri 20. Nov 2015, 11:38
Post moved to separate thread.
KyriakosCY
Users browsing this forum: No registered users and 33 guests
