X-Plane 10  Topic is solved solved with post #10805
Re: X-Plane 10
Postby hexpod » Sun 10. Apr 2016, 01:23
sirnoname wrote:Try this one ...
X-Plane.zip
With this plugin I have a strange response on yaw axis.
Is the heading effect the correct mapping for the yaw axis?
Thanks in advance for any feedback.
hexpod
Re: X-Plane 10
Postby asticher » Wed 14. Aug 2019, 00:10
I don´t get game values with v4 or default xplane plugin. I checked xplane Network settings 127.0.0.1 and Port 49000 and tryed UDP forwarding to IP4 192.168.178.1 , but no change in values.
Did i miss something?
"No Brain, No Pain"
asticher
Images: 20
Re: X-Plane 10
Postby chuenghomer » Sun 18. Sep 2022, 10:27
I tried using the X PLANE-11
which showed the X PLANE VERSION as 0. I know this fails.
Has anyone tried it successfully? On XPLANE11
chuenghomer
