Re: Assetto Corsa
Postby Kullen » Sun 16. Jun 2019, 15:08
I would appreciate if someone could help out.
Been a long time iRacing user with x-sim and now I thought that I should try out Assetto Corsa. After hours I just cant get AC to work with my SCN5 motion rig.
I have used the latest .dll suggested in previuous post as well as editing the .txt file. But nothing seems to work :-(
Edit: Just want to add that the "play game" button dont stay grey. As soon as AC start it turns blue again.
Kullen
Re: Assetto Corsa
Postby sirnoname » Sun 16. Jun 2019, 16:43
It must stay grey while running the game.
You may use the launcher option in the command line.
https://www.x-sim.de/documents/Howto-ga ... cripts.txt
Re: Assetto Corsa
Postby Kullen » Sun 16. Jun 2019, 18:07
sirnoname wrote:It must stay grey while running the game.
Thanks for your support!!!!
Had to clean the registry and start all over. Now I have motion but its all over the place.
Will have to spend some more time to see if I can sort it out.
Kullen
Re: Assetto Corsa
Postby BlancatM » Mon 4. Oct 2021, 01:18
HI I CAN´T DOWNLOAD DE ZIP... HELP
sirnoname wrote:Ok, as said the naming is difficult.
The vertical and lateral seemed to be swapped. But they are not the same.
I changed this now and also set all to zero if you quit the game.
PluginV2.zip
Now we must find out what this values are in name:
float wheelAngularSpeed[4];
float slipAngle[4];
float slipAngle_ContactPatch[4];
float slipRatio[4];
float tyreSlip[4];
float ndSlip[4];
float load[4];
float Dy[4];
float Mz[4];
float tyreDirtyLevel[4];
Too many slips and what is dy and mz? All seems to be vectors.
As minimum I need a map position and a look direction, but all this values are not named as they should normally (position and look direction I asume).
Need a description, ask someone for help here.
Here is a picture of the other plugin, the app. However the python is not stable and does sometimes not load the scripts if there are phyton calls like writing a file to disk, so it will be delayed until it is working stable:
It is based on the g-meter example and will be rewritten step by step for a simulator usage.
BlancatM
Re: Assetto Corsa
Postby martuhache » Tue 13. Jun 2023, 14:19
Hellow i cant download plugin , win rar error
martuhache
Re: Assetto Corsa
Postby Luc1gnol0 » Sat 18. Jan 2025, 00:22
c'è qualche speranza di avere il plugin per ACE?
Luc1gnol0
Users browsing this forum: No registered users and 27 guests
