Re: Assetto Corsa
Postby conceptorsp » Mon 25. Apr 2016, 15:58
já fiz tudo o que está descrito aqui e o banco virtual do Extractor não faz os movimentos; estou finalizando meu simulador 2 dof e estou preocupado; o único jogo que consegui fazer o banco virtual se movimentar foi o raceroom, mas mesmo assim depois de um tempo o movimento parou
alguém pode me ajudar?
I have done everything that is described here and the xtractor virtual seat does not make the motion ; I am finishing my simulator 2dof and I am concerned ; the only game I could do the virtual seat motion was RaceRoom , yet after a time the motion stopped
Can someone help me?
conceptorsp
Images: 17
Re: Assetto Corsa
Postby sirnoname » Mon 25. Apr 2016, 20:23
This post is not for Raceroom.
Generally it works here.
Re: Assetto Corsa
Postby conceptorsp » Tue 26. Apr 2016, 01:45
correcting
I have done everything that is described here ( in relation to installation of Assetto Corsa plugin) and the Extractor virtual seat does not make the motions; I am finishing my simulator 2 dof and want to play the Assetto Corsa on my simulator
conceptorsp
Images: 17
Re: Assetto Corsa
Postby sirnoname » Tue 26. Apr 2016, 09:42
Do your input setup in converter show changing values?
Is your play game button grey while playing game?
Re: Assetto Corsa
Postby Capripippo » Mon 6. Jun 2016, 19:16
hi guys, i have a 3dof, but i can t find the input setup for traction loss.. please help me :D
Capripippo
Re: Assetto Corsa
Postby pippo23010 » Thu 16. Jun 2016, 01:42
hello guys I have the same problem with loss of grip
how can you fix ??
pippo23010
Re: Assetto Corsa
Postby sirnoname » Sun 2. Oct 2016, 22:10
New Plugin please check if it works now longer than 30 minutes etc. ...
Please report your results here.
AssettoCorsa.zip
(732.03 KiB) Downloaded 2402 times
Re: Assetto Corsa
Postby tintao » Mon 3. Oct 2016, 07:45
Gracias
Enviado desde mi SM-A310F mediante Tapatalk
tintao
Re: Assetto Corsa
Postby Salvomilitello » Thu 20. Oct 2016, 11:35
Dont work wery well
Inviato dal mio iPhone utilizzando Tapatalk
Salvomilitello
Re: Assetto Corsa
Postby SirEisenhower » Sat 29. Oct 2016, 10:16
Hi, anyone test the new plugin?
I read all post but I have a question:
Do you install the game with autosearch in wizard or manual?
I have the script and the new plugin, but I'm not sure how works better.
SirEisenhower
