Re: Assetto Corsa
Postby brillo76 » Wed 28. Oct 2015, 12:52
I found this but I don't know if it need:
http://www.assettocorsa.net/forum/index ... ence.3352/
brillo76
Re: Assetto Corsa
Postby sirnoname » Wed 28. Oct 2015, 23:23
Yes, but please do not link, copy the file here. I always forget this login.
Here is a new plugin, copy to the /plugin directory of X-Sim:
AssettoCorsa.zip
(732.03 KiB) Downloaded 1762 times
If solved, press the solved button here. If there is a new API available, please upload here the file and unsolve the thread. Make a PM to me.
If the API date is newer in the Assetto forum than this date here in the forum it is a new API.
Re: Assetto Corsa
Postby Wanegain » Thu 29. Oct 2015, 12:13
Thank you for the plugin sirnoname !!
Wanegain
Re: Assetto Corsa
Postby sirnoname » Thu 29. Oct 2015, 19:34
Check and mark as solved!
Re: Assetto Corsa
Postby brillo76 » Fri 30. Oct 2015, 16:10
Sirnoname,
this evening I go to check if it works.
Thank you very much.
brillo76
Re: Assetto Corsa
Postby vicpopo » Fri 30. Oct 2015, 20:47
Tested and works great for me , like the previous which always was working !
Re: Assetto Corsa
Postby brillo76 » Sun 1. Nov 2015, 23:20
Doesn't work with last assetto corsa update.....
Next day I go to reinstall all the pc and let you *....
brillo76
Re: Assetto Corsa
Postby brillo76 » Tue 3. Nov 2015, 09:41
I can confirm:
after the last update assetto corsa plugin still not working.
I have try to change dll (before I had a dll about 92 kb dimension that worked fine) but no success.
Sirnoname, let me know if I can do something for helping you to solve this issue
Thanks for your time.
brillo76
Re: Assetto Corsa
Postby stazer » Wed 18. Nov 2015, 12:32
At this time ,
Asseto is running or not with x-sim with the last version 1.3.4 ?
Edit : Assetto Don't RUN
stazer
Re: Assetto Corsa
Postby pippo23010 » Tue 12. Jan 2016, 21:34
hello guys i have a problem with version 1.4.3.
There is a new plugin?
pippo23010
