Re: Assetto Corsa
Postby hape » Mon 27. Jul 2015, 19:00
TheXRacer wrote:hey hape,
i will help ypu
first open steam ...next step open Extrector as admin now open Converter as admin .......
the last point you go to Extractor options .....add you game wizard ....search automaticly.....now go to Used Game ....scroll to Assetto Corsa .....all windows will come click next/yes.....now it will craete a profil in the database midle of the window ( Motion Extractor).....now click on the profil it makes darker ....now klick -play game- ...... it will be gray .....end runs ....go to your Motion Converter and press Start :D it will works fine :D -.......
!!! check your USO options at the interface settings / from Converter.... it must be the correct settings !!!
regards
Chris
hi Chris
ithought i made all things correct but after your step by step it now works.
Many thx to you.
hape
hape
Re: Assetto Corsa
Postby sikjar » Mon 3. Aug 2015, 09:17
Thanks for the updated plugin, it works fine with Assetto Corsa Steam version 1.2.1
Sirnoname asked about the values tire slip values 93-96.
It seems they are as follows:
93 - Left front
94 - Right front
95 - Left rear
96 - Right rear
sikjar
Re: Assetto Corsa
Postby TheXRacer » Mon 3. Aug 2015, 21:06
No prob hape ...... :D
Great drivingtime .....
Chris
TheXRacer
Images: 9
Has thanked: 5 times
Re: Assetto Corsa
Postby billo2404 » Sun 6. Sep 2015, 01:34
vicpopo wrote:Hi ,
Here is the plugin inside this topic : http://www.x-sim.de/forum/viewtopic.php?f=30&t=773&start=100#p13167
Caiubbo84 told me that he won't update his plugin because he didn't use now Xsim.The plugin with the link above works but maybe should be improved.For me not so many affects as I could expect for'my 6dof.
It's a shame, I loved this game since beta and I now have to leave the 6dof?
have to pacth 0.14.626.4111 and I tried to download some of your profile for other games were great starting points and I can't get that some strange nonsensical movement.
Will there be any possibility of having a good plugin or you will have to use other software?
billo2404
Images: 72
Has thanked: 7 times
Re: Assetto Corsa
Postby vicpopo » Sun 6. Sep 2015, 09:41
Hi Billo,
I use actually the last plugin made from Sirnoname for xsim.
It works , I won't say perfectly but it works (telemetry data are sent to xsim and my sim move)
In fact I don't know if some behaviour ( shaking) coming from the game or from an effect which is not good in the right place in the plugin.
As you are from Italy maybe you can try to contact the developper with Sirnoname to clarify this. ;)
I know also because I made an Open Sim Wheel that for'the ffb sometimes something changes with a new release ac and the ffb changed.And you have to tweak the ffb settings
The last plugin is linked here : viewtopic.php?f=30&t=773&start=140#p15687
@Sirnoname : when I chose the plugin in motion driver , the plugin is well active (dot point in the checkbox) but comparating to the other in the plugin list window there is the next checkbox but the plugin is not checked ( all the others have this checkbox checked)
Re: Assetto Corsa
Postby brillo76 » Mon 12. Oct 2015, 17:46
Help,
after last AC update my x-sim stop working.
It don't say "game detected" when I start game.....
Please help.
Thanks in advance
brillo76
Re: Assetto Corsa
Postby Wanegain » Tue 13. Oct 2015, 11:17
We need an update of the plugin...
Wanegain
Re: Assetto Corsa
Postby brillo76 » Mon 26. Oct 2015, 18:31
Any news about the plugin update for assetto corsa?
brillo76
Re: Assetto Corsa
Postby sirnoname » Mon 26. Oct 2015, 22:45
Game detected is a setup problem inside the game menu.
If there is a new API, then plz post the link to the assetto page where we can download this new API.
Re: Assetto Corsa
Postby brillo76 » Wed 28. Oct 2015, 12:30
Thanks sirnoname,
but I'm very dumb about this argument and I don't understand your answer.
I think that you need somtehing for update plugin, but I don't know where I can find it.
brillo76
