Re: Assetto Corsa
Postby sirnoname » Mon 1. Dec 2014, 00:26
There is a "launcher" parameter for this. Launcher is the game launcher, exe ist the executable which will be waited for.
The script tutorial shows such setup.
Re: Assetto Corsa
Postby vittobrambi » Mon 1. Dec 2014, 20:31
OK thanks, now the converter is working, the values are changing...
Actually only yaw, pitch and roll. Not long lat forces.
Is there a plugin also for forces?
Thank you
Vitto
vittobrambi
Re: Assetto Corsa
Postby vittobrambi » Mon 1. Dec 2014, 23:38
Hi, finally I succeeded in running my sim with assetto corsa.
I used the plugin by Caiubbo.
download/file.php?id=3374
It has long and lat forces and it is working fine (a little rippling on longitudinal forces need some smoothing). Lateral forces perfect!!
A big thank to Sirnoname and Spiderwash for their help.
Vitto
vittobrambi
Re: Assetto Corsa
Postby DangerouS » Sat 13. Dec 2014, 15:59
vittobrambi wrote:Hi, finally I succeeded in running my sim with assetto corsa.
http://www.x-sim.de/forum/download/file.php?id=3374
Vitto
I used this same dll but first gear is "1" and no "N".
Any solution?
DangerouS
Re: Assetto Corsa
Postby Wanegain » Tue 6. Jan 2015, 16:16
This is a known issue (I noticed it last here). I hope it will be fixed soon :oops:
Wanegain
Re: Assetto Corsa
Postby vicpopo » Wed 7. Jan 2015, 21:49
Hi Users of Assetto Corsa,
I'm made a profile for Assetto Corsa with Sirnoname plugin and I don't like the result of my profile.It shakes a lot and for me that doesn't match to the reality .
In Game when driving I displayed the G-forces ( lateral,and loongitudinal) and often at low speed the both cursors and mostly the longitudinal cursor moves forwards and backwards and the simulator is obviously very jerky.
For me these vibrations are very difficult to setup with the profile.
Did you notice the same problem et how did you solve it ? Thanks
Re: Assetto Corsa
Postby Wanegain » Wed 7. Jan 2015, 23:35
Hi Vic !
Yes I noticed it, it's very unpleasant when you are leaving pits because of the speed limiter.
No solution for me, I accelerate fully in pits and I increased the maximum value...
Wanegain
Re: Assetto Corsa
Postby vicpopo » Wed 7. Jan 2015, 23:51
Hi Wanegain!
Merci pour la réponse .C'est hyper desagréable.Je vais essayer encore.
Thanks , I'm not alone .it's very unpleasant full agree with you , I will make an another try.I used the mean value filter to minimise the problem but not yet perfect.
Hope this problem will solved soon.
Keep in touch for that.
Edit': I used peak filter isntead mean value filter to try to minimise the problem
Re: Assetto Corsa
Postby Wanegain » Sun 11. Jan 2015, 13:42
Est-ce que tu as essayé l'autre plugin : http://x-sim.de/forum/viewtopic.php?f=30&t=1376 pour voir si ça changeait quelque chose ?
Did you try the other plugin (Assetto Corsa plugin plus) to see if it changes something ?
Wanegain
Re: Assetto Corsa
Postby vicpopo » Sun 11. Jan 2015, 14:37
Ben non car il n'est plus accessible.J'ai fait un MP à caiubo84!
Not yet downloade able .I sent a MP to caiubo84.
Thx !
