Re: Assetto Corsa
Postby nicotriv » Wed 9. Jul 2014, 10:58
sirnoname wrote:I changed the detection of the game for the Game wizard. So you have to use the X-Sim registry cleaner and press the extractor button. After this you have to enter again the forum user. After you did this, close the extractor and extract and copy this files:
Copy_to_plugin_folder.zip
Then delete all assetto entries in left extractor box and do a wizard autoscan again. I need this verification for correct detection.
The steam version should be detected with a app id in the properties of the game (left box).
After starting the play game button must stay blue.
Then I need verification off all accelerations.
Last but not least I need verification of the effect 93 to 96. Should be tire slip but I do not know how to verify which number is which wheel :(
the motion is back with this patch? thanks
nicotriv
Re: Assetto Corsa
Postby gabry1090 » Wed 9. Jul 2014, 14:22
i cannot work out how to make the game work properly with this plugin, i'm sure it's my fault, later i'll try again!
gabry1090
Re: Assetto Corsa
Postby spyderwash » Wed 9. Jul 2014, 18:56
ok i had time to try the new plugin I tried installing the game is detected, but does not compile the steam box call parameter values ​​are accurate motion data is missing sin lost traction was inserted into the plugin caiubbo84 good feeling recreating the values 93 to 96 I did not understand what I recreate some force to each tire 93 94 95 96 front and rear lost traction wonder if can insert that was in the position plugin caiubbo 84 37 I do not have the chance to make a change to these.
Thank sirnoname availability and the people who work at the forum.
I apologize for using a language translator
spyderwash
Re: Assetto Corsa
Postby gabry1090 » Wed 9. Jul 2014, 20:56
now i got it working! thanks very much sir! in these days i'll make a profile since i bought assetto only when they released the update and i couldn't try it yet! then i'll let you know about forces!
gabry1090
Re: Assetto Corsa
Postby jomaho » Wed 9. Jul 2014, 23:25
Confirm working. Thanks sirnoname, and whoever else helped!
jomaho
Re: Assetto Corsa
Postby nicotriv » Thu 10. Jul 2014, 10:24
sorry, but i don't understand what i need to install and how to configure... :cry:
any help? many thanks
nicotriv
Re: Assetto Corsa
Postby spyderwash » Fri 11. Jul 2014, 10:15
Read the post on page 7 explain to you what files to replace
spyderwash
Re: Assetto Corsa
Postby Balles » Sat 12. Jul 2014, 09:29
Thank you very much sirnoname, it works like a charm.
Balles
Re: Assetto Corsa
Postby nicotriv » Sat 19. Jul 2014, 10:48
the last published XSim plugin works with the new 0.21 build of Assetto Corsa? any problem?
I have not yet updated the game :D
many thanks
nicotriv
Re: Assetto Corsa
Postby nicotriv » Sun 20. Jul 2014, 23:43
all ok? i can update the game? :roll:
nicotriv
Users browsing this forum: No registered users and 35 guests
