My 2dof project noob..
Postby dipa » Sat 1. Jun 2013, 15:52
Hi guys
This si my cockpit i created two years ago.
In this time I have read many topics on the forum,
165316521651
Now i just started with new project but i need help to find the right component for that project.
The thing is to install 2 wiper motor in the two side of the pedals.
I need suggestions on the electronic part,
Velleman and sabertooth or other (more easy to do)?
in the meantime I ordered the wooden base that will sustain the old structure.
on this basis will install engines wipers...
for now I have to find all the material to complete the frame.
dipa
Images: 7
Re: My 2dof project noob..
Postby RacingMat » Wed 5. Jun 2013, 14:43
hello Dipa !
I wish you good luck for your 2DOF playseat ;-) that's a nice project !!
My 2DOF 12V DC wiper playseat is based on Arduino / Motomonster :
1634
I like Arduino because I can change some parameters easily by myself in the C code
- wiper motor's max speed
- angular range ...
and it's scalable to 3DOF or can drive other options (LCD, ...)
If you choose this way, I'd be able to advise you.
You will although find more information as soon as my project will be posted in the finished project gallery (awaiting for admin's answer).
By the way, I do like your load cell pedals ! I'm working on mine right now
Do you have bigger pictures ? I'm curious about the fully pressed position of the right pedal...
Mat
Postby dipa » Sun 9. Jun 2013, 16:07
I am happy of it, i can take some pictures for you.
The pedals was my first project diy.
Now i want to make an upgrade of it...
About Your project i think Its great, but i don't know how i can program in c code...
is it difficult?
for Your solution si necessary another pc?
dipa
Images: 7
Postby dipa » Sun 9. Jun 2013, 18:13
these are the pictures you need
1679
Here you can see the hall effect sensor under the adhesive tape
1683
And the fixing point of the magnet
1681
1680
For the magnet i use one of old cyclocomputer.
dipa
Images: 7
Postby RacingMat » Mon 10. Jun 2013, 12:26
Nice pictures ! Thanks :-)
You don't need any programming skills : if you follow my post you can simply copy and paste the code attached !!
It's ready to use !
The second PC is not mandatory : it's advisable !
Mat
Postby dipa » Mon 5. Aug 2013, 15:22
I want to follow your way with arduino and
Motomonster.
At home i have the plane wood, but now
I have to order the power supply 12v 30a, atx,
Arduino and motomonster, but where i can find
2 Good pot?
P.s. My pedals upgrading is started with
2 pneumatic cilinders and 1 linear sled pot
For throttle. 1 hall sensor for the brake.
And Now i can start testing it
dipa
Images: 7
Postby RacingMat » Mon 5. Aug 2013, 22:57
Hi Dipa !
you can buy any cermet potentiometer : "cermet" means Ceramic Metal.
It guarantees you that it's the strongest design compared to plastic-carbon low cost pot.
- cermet
- linear (not logarithmic)
- 10 kOhm
I bought mine at http://www.gotronic.fr/art-potentiometre-lineaire-cermet-10k-8486-11293.htm
you can find here many other electronic distributors : http://codelab.fr/177
Postby dipa » Thu 8. Aug 2013, 15:53
dipa
Images: 7
Postby RacingMat » Thu 8. Aug 2013, 17:45
To anwer to your question, you need to calculate the current needed by your motors !
-> but, if you choose the same motors as mine, it's okay !
(check the end of my tutorial, I've just added electrical power consumption information).
>ingresso: AC input 100-120VAC
Beware ! you're not in 230V in Italy ?
Postby dipa » Thu 8. Aug 2013, 19:58
Yes we have 220v :D
I 'll buy 2 whiper motor used, then i can read the datasheet...
With Your ups i don't know if i can make the fix...
I don't understand how i can solder the wires of neutral and line... :?
dipa
Images: 7
