Please help me!
Please help me!
Postby billykindell » Sat 18. May 2013, 23:55
Hello, I am not sure where else to post this so I hope you guys can help.
I have been trying to extract RPM data from F1 2012 now for a very long time, and i can not work out how to get ANY values working. Any help would be great, Thank you so much
billykindell
Re: Please help me!
Postby sirnoname » Sun 19. May 2013, 02:39
Start X-Sim extractor, connect via network or serial port to OBD2 interface (WLAN/Network is easier) -> use a manual of the ELM327 OBD II interface chip and read out the data as you would do with a real car. Use any Android, notebook or iPad OBD2 app as reference. (i.e. torque)
It is automotive standard.
Re: Please help me!
Postby billykindell » Sun 19. May 2013, 14:21
Thanks for the reply.
What i am actually trying to get the data for is the shift indicator lights (The red,green, blue). I was trying all different things for about 5 hours this morning and made no progress
billykindell
Re: Please help me!
Postby sirnoname » Sun 19. May 2013, 15:57
You are using the converter?
Some details about what you try to do would be fine!
Re: Please help me!
Postby billykindell » Sun 19. May 2013, 19:47
I am using the converter etc.
I am trying to get values to use with the arduino uno...
billykindell
Re: Please help me!
Postby prodigy » Sun 19. May 2013, 20:06
You have an arduino dashboard?
Re: Please help me!
Postby sirnoname » Mon 20. May 2013, 00:55
I found a bug that do disable, in 3.0.1.4 converter app, the update of the input setup. This means the listbox is not updated, the values in the math do work.
Only a monitoring problem.
Did you look at the input setup box (converter) or did you use the math setup?
Re: Please help me!
Postby billykindell » Mon 20. May 2013, 18:49
Why did you close my project thread?
And yeah, just before I cam on here I had a little play and found that they do work. Thanks :)
billykindell
