This Is My Actual simulator ...
I Have Build A 2DOF WiperMotor With sabertooth/k8055..
Thanks...
sirnoname wrote:First you install FSUIPC, then you open FSInterrogate2std.exe and find the values you like (pitch roll).
Add the game executable to the extractor game list, select the msflightsim plugin in the plugin driver and input the values you like to use in that plugin.
If the values reach the converter you can think to make profiles with that values in the same way you do for car games. However solve this steps first.
A K8055d is not used for electric motors, it is used for pneumatic. Buy a arduino.
