simdrivers weight
simdrivers weight
Postby seppel » Tue 29. Jan 2013, 21:58
hi all,
maybe a 1000times answered question but necessary for my further planing:
what kind of motor or actuator can i use with a driversweight of 110kg(without seat, frame, bottle of bear :)
i read in the forum that, if the seat is pretty good balanced, the popular motors can handel the weight.
thx
rgds
seppel
seppel
Images: 34
Re: simdrivers weight
Postby value1 » Tue 29. Jan 2013, 22:10
Indeed, if you have your sim nicely balanced there is not a lot of power needed to move it.
Commercial simulators including most hydraulic steward platforms have the axis not going through the centre of gravity. They can do this because of the sheer power they possess.
With a wiper motor (or essentially almost any other 12V motor) you NEED to balance your sim. If you wish you can do the math, and come to the same conclusions.
I also had in my original design the centre of gravity above the axis by purpose and against the recommendations of the guys here.
At the end I had to realise the guys here were right. :)
value1
Images: 3
Has thanked: 12 times
Postby motiondave » Tue 29. Jan 2013, 23:45
Ive had 110kg on a wiper sim, moved him no worries .
just a matter of balance.
Postby seppel » Wed 30. Jan 2013, 19:40
thx for quick and helpful answers.
i´m afraid that i must go to weight watchers :roll:
now next step is to go to the drawing board and plan the ground construction.
seppel
Images: 34
