hallo everybody a question !!
Postby stefanosdimos » Fri 4. Jan 2013, 19:55
i m new here !! first of all i want to ask -the games must be original ??
stefanosdimos
Re: hallo everybody a question !!
Postby tronicgr » Fri 4. Jan 2013, 20:14
Ναι, πρεπει να ειναι αυθεντικα. Διαφορετικα με πατσαρισμενο exe τα plugins δεν θα διαβαζουν τις ιδιες τιμες στην μνημη πιθανοτατα.
Θανος
Postby stefanosdimos » Fri 4. Jan 2013, 20:20
σ ευχαριστω θανο !! μια ερωτηση !! γινεται πολυ χαμος με software !! θα βγαλω ακρη αν δεν ειμαι ηλεκτρονικος ??
stefanosdimos
Postby motiondave » Sat 5. Jan 2013, 09:22
stefanosdimos wrote:i m new here !! first of all i want to ask -the games must be original ??
Only if you want to play online.
I have used cracked versions of dirt 2 , 3 . F12010,2011 , rfactor , grid .all work fine offline. You need genuine versions for online , although rfactor is accepted as a cracked version on most servers.
Postby stefanosdimos » Sat 5. Jan 2013, 09:52
thank you !!!!!
stefanosdimos
