Hello + Novice questions
Postby Kangapawns » Thu 30. Aug 2012, 09:23
Hello to all Admins and Members,
I have read many ..many ... MANY different builds and sims and decided it was something i wanted to create.
So far i have most of my 2dof full frame movement sim complete. I built the frame, seat and everything i possibly could weld/sew or nail together :D
I would have taken on making my own control cards but I am not that good any longer at that sort of stuff >< plus i had a few spares from previous projects from school and other sorts :D
My main issue is the connecting of the k8055n to 2 x pololu 24v23. I understand how they work but for the life of me its confusing how i connect them to talk to each other...PMW k8055n output with TX connection on the 24v23? or do i use the analog input for pots on the 24v23? or do i use digital outputs from the k8055n and connect them to the TX connection or the analog pot connector? agghh just typing this seems confusing :S
Any help by either PM or post would be greatly appreciated as I am not connecting anything just to test and blow it up(knowing my luck),
Thanks in advance,
Kangapawns
Re: Hello + Novice questions
Postby motiondave » Thu 30. Aug 2012, 14:54
Have a dig through here, there is some info on K8055 that may help
