helps to set a servo motor via synaptrix
Postby TheMenace » Wed 14. May 2014, 05:39
Hello I started a project to make a 6DOF simulator and I am wanting to use some servo motors that already have, them are controlled by their original drive via the serial port.
Is it possible to send a signal from one axis to the serial port and turn this engine?
Would have to have exactly what this work? I thought about programming via sinaptrix,
Thank you
TheMenace
Re: helps to set a servo motor via synaptrix
Postby sirnoname » Wed 14. May 2014, 13:18
Synaptrix is a teach in interface for hydraulic and pneumatic.
I think you search for USO:
http://www.x-sim.de/manual/uso.html
