hi some questions
Re: hi some questions
Postby ef696 » Sat 12. Jan 2013, 20:44
hi yes it seems its a rear wiper motor....but good enough for test and learning how to set up software yes?
why do i have to play with pid setting anyway I thought the x-sim software recognized card and I don't have to do anything?
I looked at this plugin but this plugin require me to use polou configuration utility. Is that really easier than daves video of adding board and one step further of adding uso command?
Also will x-sim work if I am just using Keyboard or I have to buy wheel or joystick? Please reply this so I know as I been just using keyboard. I will buy joystick or wheel if you say it doesn't work.
thanks again guys
ef696
Postby motiondave » Sun 13. Jan 2013, 00:29
The PID settings are to get the motor to run properly . Surely you can change some numbers.
The motor will be fine for testing and getting used to the software.
The plugin is for making thejrk more plug and play.
I only offered the USO commands as a choice . It's to help get you started .
A video of the plug in instructions needs to be done,and usually I do them, but my kids are home on school holidays .i will not get to it till February .
If you are not sure about the plug in at this stage, use USO .
The pololu utility is for setting up how the motor reacts, hence a feedback setting and PID.
You need to change the PID , it will help your motor to be less twitchy .
Postby motiondave » Sun 13. Jan 2013, 00:31
AnD yes the program works with a keyboard , as the keyboard controls the car in game.
Then go buy a wheel later.
Postby ef696 » Sun 13. Jan 2013, 03:11
Hi thanks dave
Can you tell me why I get this message
ef696
Postby motiondave » Sun 13. Jan 2013, 03:38
load the extractor program.
http://www.youtube.com/watch?v=x3_WsBRmgqM then watch this to start the program to play games.
Postby ef696 » Sun 13. Jan 2013, 04:21
I have uninstalled/reinstalled, cleared registry 2 or 3 times , this is what is happening, the extractor is running in background but the only thing I am able to do is scan for game then when i click quit the little window closes and there is no more access to extractor.
ef696
Postby motiondave » Sun 13. Jan 2013, 07:41
what version of windows are you running,
did you allow all x-sim related programs through firewall.
are you running more than one screen?
Postby ef696 » Sun 13. Jan 2013, 08:20
I am running windows 7
I added x-sim to exclusions in avast program
I only have one screen
I can open these 2 windows from the task bar but can't open the extractor window....but it is running in the background
extractor worked before when i started this journey last week but today no more :lol: ....it just gets harder? :lol:
ef696
Postby motiondave » Sun 13. Jan 2013, 08:37
got me stuffed.
send an email to sirnoname. he may have a better idea than me.
Postby prodigy » Sun 13. Jan 2013, 14:13
It looks to me like you have same problem as I and caiubbo got. Extractor is running but there is no window. Try this:
1. You need to click on taskbar button of Extractor to make program active, even if you see no window - IMAGE
2. Then you press ALT+SPACE to get window menu in corner of desktop - IMAGE
3. With your arrow key on keyboard choose "Move" from menu, click Enter and move arrow keys to move window
This helped for me.
