Simulator Help
Re: Simulator Help
Postby elvisowned » Sun 30. Dec 2012, 16:15
BobBuilt wrote:Can ya send us a better pic on Mitsubishi s500 inverters or a link, if this only requires a 5v signal to operate than , Im gunna get shot for this, I would trail a k8055 in place as the controller. It has the capabiles of controlling two motor, this is not your best option we could proberly do a lo better as the k8055 is a little slow but clever profile wrinting ya will have it back to a pc controlled arcade machine and in the future with a real controller it could become a kick arse simulator.
Hi Bob
Here is the link http://www.manualslib.com/manual/104397 ... -S500.html
Thanks for you help.
elvisowned
Images: 16
Re: Simulator Help
Postby elvisowned » Sun 30. Dec 2012, 16:46
elvisowned
Images: 16
Re: Simulator Help
Postby elvisowned » Sun 30. Dec 2012, 23:08
Hi Bob
Here is the link to the manual. http://www.allied-automation.com/pdf/S5 ... Manual.pdf
Thanks David
elvisowned
Images: 16
Re: Simulator Help
Postby elvisowned » Mon 31. Dec 2012, 15:53
Hi Bob
I found out the control board is a comercial board. Its a BASE-c64r by Comfile technology. It looks like it was manufactured in Korea.
Hope this helps, thanks Dave
928
elvisowned
Images: 16
Re: Simulator Help
Postby elvisowned » Mon 31. Dec 2012, 20:14
Hi Bob
Here is a close up of the board. It's a "BASE-c64r from Comfile Technology, copyright 2000, vol 2.0 fro TPC38 (www.comfile.co.kr). They have a office here the united states but I'm sure they originated in South Korea. I included a few photos of the motors with the actuators the move the chair (three total.) There is also a 4th motor that rotates the chair 360 degrees. 954951953957949950
Thanks David
elvisowned
Images: 16
Re: Simulator Help
Postby sirnoname » Wed 2. Jan 2013, 12:22
Re: Simulator Help
Postby elvisowned » Thu 3. Jan 2013, 13:01
Hi Bob
Could you send your email adress to me directly. I tried to
Send the photos via the message board and it won't let me paste the photos
into the email.
Thanks David (collins3076@netzero.net)
elvisowned
Images: 16
Re: Simulator Help
Postby bartez81 » Fri 8. Feb 2013, 11:07
Hello
Maybe someone know how to connect the inverter to the k8061? I plugged the analog but the engine is in one way. Just as if getting +10v. What to do to vm140 worked in a range of + /-10v?
I'll be grateful for your help.
and put a beer :)
bartez81
