Force feedback driver and ignore list ?
Postby ericRacer » Thu 14. Mar 2013, 12:38
I used FF driver recently for the first time and it works well. I saw in the documentation that there was an "ignore list" that I never found, so where is it?
Another thing, after finding the strength and selected what I wanted, it appears one other small window with a message telling me that x-sim scored 2 or 3 strengths of this type and wonder if this number is good or something like that, what do I do with this info?
thank you,
Eric
ericRacer
Images: 36
Re: Force feedback driver and ignore list ?
Postby sirnoname » Thu 14. Mar 2013, 13:01
Both questions are for the redetection of the effects.
If you start a game the game developer init the force on your wheel. For example one sawtooth and two constant forces.
He can do this init with the first values inserted or with zero informations. You see in the ignore list the init values and you can decide to ignore one changing value if the effect is not redetected correct. The other option is to detect the correct value with asuming it is the third or forth that is init by the game developer. The score box tell you that there are more than one effect inits with same effect values and you should think about count them from the init start. You need to change the count number if the effect is not redetected if you start the game again.
Postby ericRacer » Thu 14. Mar 2013, 13:30
thank you for the quick response!
[[* Both issues are for the effects of the redetection. *]]
If I understand the ignore list * became * the score box ! 8-)
And if the effect is detected at any time I restart the game, I did not change this number ! :mrgreen:
thank you again
Eric :D
ericRacer
Images: 36
