Extractor Starts (I think) but I cant see it
Postby RafBR » Thu 7. Feb 2013, 04:09
:cry:
I made some changes in my hardware and after that I think extractor is starting out of my screen visible are.
Maybe it because my videocard is broken and now I am not able to set eyefinity anymore.
So my guess is that, the extractor process is running its window somewere.
I tried to use the bugtracker but I could not find how to.
If anyone went thru this problem before please let me * Is there a way to reset the start position for extractor window? I already tryed registry cleaner without success.
my regards,
Rafael.
RafBR
Images: 24
Re: Extractor Starts (I think) but I cant see it
Postby sirnoname » Thu 7. Feb 2013, 12:11
Hello Rafael,
please goto the bugtracker, select the X-Sim Software 3.0.x.x, select bugtracker and then press the link on the top to create a new ticket.
Fill out the form and the problem will be solved.
If you have some more problems with the bugtracker you can open a bug ticket in the bugtracker under "Webpage".
No, this is a joke, please write me a pm ...
Thank you,
SirNoName
Postby RafBR » Thu 7. Feb 2013, 16:50
Thanks Sirnoname, I guess I am used to the large "NEWTOPIC" buttom and bugtracker have a little one :D
RafBR
Images: 24
Postby RafBR » Thu 7. Feb 2013, 19:34
prodigy wrote:Hey, I had the same problem, this happens sometimes, don't know why, the extractor is active but its window dissapear. Try this if it helps:
1. You need to click on taskbar button of Extractor to make program active, even if you see no window - IMAGE
2. Then you press ALT+SPACE to get window menu in corner of desktop - IMAGE
3. With your arrow key on keyboard choose "Move" from menu, press Enter and move arrow keys to move window on your desktop
Thank you Prodigy, it worked! :D
I am not sure what the problem is/was but maybe Sirnoname could tell if there is some kind of "reset window position" on Registry Cleaner tool.
Regards!
RafBR
Images: 24
