Login problem.  Topic is solved solved with post #24739
Login problem.
Postby masibabato » Tue 12. Jan 2021, 16:36
When I am trying to log in the extractor it says "Login accepted, waiting for verification",
Any help please?
masibabato
Re: Login problem.
Postby BlancatM » Wed 13. Jan 2021, 02:46
hi, i have problems with extractor, it stays in starting program. yesterday everything worked perfect, log into IE, FIREFOX and CHROME and close sesion ... everything is fine. I have no problem starting with browsers .. x-sim extractor is the problem does not start.. windows 10 pro and x-sim 3.0.3 please help :oops: :oops:
BlancatM
Re: Login problem.  Topic is solved
Postby sirnoname » Wed 13. Jan 2021, 08:49
same here, I will have a look at it.
Re: Login problem.
Postby masibabato » Wed 13. Jan 2021, 11:55
I think I had a windows update before stop working !
Not sure if that helps.
masibabato
Re: Login problem.
Postby sirnoname » Wed 13. Jan 2021, 18:10
As far I can see here, the online version is broken and will not work anymore. So the offline version need the check at the "total offline" option.
It seems a deeper problem, so I need some days for a fix.
A little bit more questions are about the microsoft plan to remove the internet explorer from windows. I do not know if the embedded explorer for X-Sim will stay in windows.
The reason for this behavour is the last windows flash remove build. Now all flash elements in the page cause a crash in embedded browser like X-Sim is using.
Re: Login problem.
Postby BlancatM » Wed 13. Jan 2021, 19:56
HOOOO ... WHAT THE HELL ... :( :( :( :( :(
ok I'll try to buy the offline version I was just testing my engines before starting to build the structure. Ask, if the online version cannot log in, how will it be done to enable the offline mode with the internet connected, thanks ...
BlancatM
Re: Login problem.
Postby sirnoname » Wed 13. Jan 2021, 23:32
Searching for tester for a fixed version.
Re: Login problem.
Postby masibabato » Thu 14. Jan 2021, 00:45
I can test if you have a fix for it if that is what you mean. :D
masibabato
Re: Login problem.
Postby plutofirenze » Thu 14. Jan 2021, 15:31
Hi all,
I have the same problem, once typed User and pSw, the extractor is stuck and the message is" Login accepted, waiting for verification..."
does anibody found a solution?
plutofirenze
Re: Login problem.
Postby Bergison » Thu 14. Jan 2021, 18:18
Sirnoname, I'de be happy to test anytime! Thanks for your work!
Bergison
Images: 20
Been thanked: 9 times
