dirt rally 2 hardware config
Postby kappacina » Thu 9. Jul 2020, 20:55
Hi everyone, I solved the plug-in problem, now i see the data coming to the converter but the platform has decided not to move :-). Who gives me the right configuration in the hardware setting in my games dirt rally 2 folder? Xbox Is set ti false, udp enabled is true and extradata 1. I also tried on 2 and change from true to false but it doesn't work. the data arrives but it doesn't pass me through the platform. Thanks a lot for the help
Denis
kappacina
Re: dirt rally 2 hardware config
Postby sirnoname » Fri 10. Jul 2020, 12:53
You may read the manual:
https://www.x-sim.de/software.php?lang= ... e=gamelist
Or you try step by step. extradata 0 is lfsplugin, extradata 1 is codemaster plugin. So many solutions ...
