Trying to get extractor to recognise FS X
Postby mambomachine » Thu 9. Apr 2020, 21:46
Hey there,
Have successfully connected converter to recognise RACE 7.
Now trying with FS X
Add your games/ Wizard ... does not find FS X
I add manually - open advanced and manual setup: (leaving options "answer all questions with yes and sort out the result of the scan" checked on)
Put in location of FSX : C:\Program Files (x86)\Steam\steamapps\common\FSX\fsx.exe
It then suggests I use X-Sim motion driver. I change this to MSFlightV2
Call parameter : steam://rungameid/314160
Add that to game list.
When I go to run the game a message pops up :
"Auto setup"
There is a official game plugin detected for this game executable. Do you like to activate/ change this plugin in motion driver dialog?
I say either yes/no it doesnt matter both fail
at this point x-sim hangs. If I choose another plug in .. there is no comms back to the converter.
Any ideas?!?
mambomachine
Re: Trying to get extractor to recognise FS X
Postby sirnoname » Fri 10. Apr 2020, 17:45
Check first FSUIPC is working. The Plugin is is using this.
