Server connection problem (deactivated)  Topic is solved solved with post #23960
Postby electrosim » Fri 15. Nov 2019, 14:33
Hi Sirnoname, yesterday I used Xsim online and everything worked fine. Now I have started Xsim but I get a warning message from Extractor:
Errore nel supporto per il canale sicuro
Offline mode deactivated
Load server list
Get active servers
Is it a problem with your server?
electrosim
Re: Server connection problem (deactivated)  Topic is solved
Postby sirnoname » Sat 16. Nov 2019, 00:26
Yes, since debian 10 the server hdd crash all month. I did switch back *
Postby electrosim » Sat 16. Nov 2019, 16:26
ok, when it will be running again?
electrosim
Postby sirnoname » Sat 16. Nov 2019, 16:38
Since I wrote the last post.
