Offline mode deactivated  Topic is solved solved with post #23947
Postby Commodore » Thu 7. Nov 2019, 03:21
Hello Sirnoname,
unfortunately the server problem is present again.
Could you restore server operation?
Thank you in advance
Commodore
Re: Offline mode deactivated  Topic is solved
Postby sirnoname » Thu 7. Nov 2019, 18:44
No, all is working fine.
Postby Commodore » Thu 7. Nov 2019, 20:06
ok thank you, you're very kind for your help.
I have a question for you: Today I tried using xsim without internet connection chapta coffee breaks. but while waiting for the seconds appeared the message "X-Sim data collector has stopped working", and extraxtor closed.
what is the cause of this error?
I use Windows 10 (x64).
I am looking forward to receiving your valuable answers. thanks for your help.
Commodore
