Error extractor  Topic is solved solved with post #22428
Postby zapata » Mon 19. Mar 2018, 02:52
Good to all, I have a problem with extractor, when executing as administrator it stays in get last profile, run last plugin, but when removing from the folder xsim the plugin dirt2plugin.dll starts without problem and if I put it in the folder again is hanging, any solution?
zapata
Re: Error extractor
Postby profphil » Thu 22. Mar 2018, 16:49
i got the same issue, but i got it working by dragging the outsimdirt2 plugin on the Desktop and deleting it in the plugin Folder. Whenever i want to run dirtrally ,i first start the Extractor and then double click on the outsimdirt2 Icon on the Desktop after this you can start the game by clicking on the Play game button as normally.
profphil
Re: Error extractor
Postby zapata » Fri 23. Mar 2018, 09:00
Thank you very much for your response, I will test your method to see if it can work, greetings
zapata
Re: Error extractor
Postby zapata » Sat 24. Mar 2018, 11:15
profphil wrote:i got the same issue, but i got it working by dragging the outsimdirt2 plugin on the Desktop and deleting it in the plugin Folder. Whenever i want to run dirtrally ,i first start the Extractor and then double click on the outsimdirt2 Icon on the Desktop after this you can start the game by clicking on the Play game button as normally.
Investigating about the solution you have proposed I think I have found the solution, in my case it is about installing the x-sim software outside the program files folder, in another directory that is not that, a friend told me that with others different programs the same thing happened to him and it was solved in that way, at the moment it works correctly
zapata
