Extractor hung since win10 creator update  Topic is solved solved with post #22192
Postby asticher » Fri 7. Jul 2017, 02:18
Since Win10 "Creators" update the extractor hung (process x-Sim data collector) when starting the profil/Dcs Plugin.
Last Message is:
"Get last profile
Run last plugin ..."
I tryed:
- a clean re-install,
- change the wizard txt (launcher.exe to DCS.exe)
- changed the user rights for plugin/converter/extractor (full rights all users)
- changed compatibility mode "Windows 7" for plugin/converter/extractor
all didn´t help.
When deleting the DCS Plugin the Extractor starts.
So, I think it could have something to do with new MS Visual C++ Redist. Software which comes along with the creator update.
Anybody else sharing this issue?
Thanks for any advise or hint.
"No Brain, No Pain"
asticher
Images: 20
Re: Extractor hung since win10 creator update
Postby skihnia » Thu 24. Aug 2017, 10:36
I'm having the same issues.
How did you solve this? Extractor hung every time I do anything outsim related.
skihnia
Postby Juakinorro » Tue 5. Dec 2017, 15:57
Solution pleasw???
Juakinorro
Postby Venflon » Sun 17. Dec 2017, 16:52
is nobody working on this?
Venflon
Postby upracerr » Sun 17. Dec 2017, 22:38
Hi, seems IT is solved, but i cant find the solution. Gott the Same issues....
upracerr
Postby asticher » Fri 26. Jan 2018, 16:43
No the extractor don´t start anymore with the newest win 10 upgrade.
I´ll tryed to install all old runtimes (AIO Runtime lib) but this didn´t help.
Only uninstall the win10 upgrade helps.
"No Brain, No Pain"
asticher
Images: 20
Re: Extractor hung since win10 creator update  Topic is solved
Postby sirnoname » Fri 26. Jan 2018, 20:43
Working fine here.
Check your admin rights on folder and every executable.
Postby asticher » Mon 29. Jan 2018, 13:56
Update: ReInstall in user default dir and it works again! Thanks Sirnoname!
"No Brain, No Pain"
asticher
Images: 20
Postby erivx » Tue 30. Jan 2018, 16:38
hey gente.
Bueno verán yo empece a usar el xsim por septiembre del 2016 y a mí siempre me botó ese mensaje que dicen de cargar nuevo perfil, y esas cosas. Por enero del 2017 seguía usando hasta que me salga y funciono con Rfactor, y cargando los plugs-ins que te pide extractor cargar automáticamente. Ah! y también cuando seleccionaba un perfil se borraba la descripción, aun así me funcionó, aquella vez que aun recuerdo. Ustedes tienen comprado el programa o usan el libre(gratis)
erivx
Postby sirnoname » Tue 30. Jan 2018, 21:39
The normal way is to grant access with rightclick the x-sim folder and set the security in options. This part is changing step by step in W10.
