Strange behavior and dropping connection
Postby petaks » Mon 22. May 2017, 16:44
Running X-sim locally on my Win7 x64 PC and have had so many issues since I started using it with disconnects
and games not found even if Autoscan put them in the list.
The latest is this: Assetto Corsa starts up fine, extractor running and sending data to converter but only for a few seconds and then killing itself.
Tried to find a logfile explaining what is going on but failed.
Plugin updated to the latest I could find here, only using bass shaker now and really don't
feel that I need to buy other gear as I can't get them working using X-sim.
Short video:
petaks
Re: Strange behavior and dropping connection
Postby mkeymont » Fri 2. Jun 2017, 12:45
Apologies if I'm reading this wrong, and I don't play A.C., so maybe it's different from iRacing, but what appears to be a part of the issue is that you should be starting A.C. from the extractor app. In your video the game is already running when you press the Play Game button.
For iRacing at least, I open the extractor app and launch iRacing from within the app. When I do that, the connection to the converter is established and it starts working. It looks like you already have the game running and somehow getting data to the converter, but when you hit the play game button, the data seems to stop flowing.
I've been through months of issues myself with making this work right, but I seem to finally be there. I have had luck with some things by re-installing x-sim.
mkeymont
