impossible to launch X-SIM since last windows updt
Postby TheStick » Sun 14. May 2017, 02:57
Hy,
My PC under windows 10 applied a big windows update.
I'm not sure this is the cause but just after Extractor refuses to launch. I just obtain the circle rotating permanently and blocking on the message "Get last profile Run last plugin..."
I tried to uninstall and totally erase the X-sim file. Then I reinstalled Xsim => I allways got the same symptoms.
Am i alone ?
TheStick
Re: impossible to launch X-SIM since last windows updt
Postby sirnoname » Sun 14. May 2017, 13:14
Admin mode?
Postby TheStick » Sun 14. May 2017, 23:26
Hy,
Yes i am admin. Otherwise, there is an error.
Actually it's a bit better. i tried many things:
reinstall, remove the profile.db, remove the *.rn2 in my profile, remove the "HKEY_CURRENT_USER\Software\X-Sim" key i, the registry
and then remove the registry key : "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\X-Sim" and it works.
but i should all reinstall.
I checked if everything is working with DIRT3 => yes
allright but when i relaunch everithings => Extractor bugs as last time.
I finely realise that i could launch and use X-SIM, if i destroy the string value "Plugin_Path" in the key "HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\X-Sim\Force-Sender" which for me, is containing, "E:\X-Sim\Plugin\LiveForSpeedPlugin.dll"
After that, i should re-edit the motion driver i need to use. Then it works, but it's not usefull. It's so strange, i use it since many years...
TheStick
Postby sirnoname » Mon 15. May 2017, 23:52
You must run the x-sim registry editor as admin.
Reinstall also with admin to delete all old values.
Postby yuquanhai » Mon 14. Aug 2017, 05:23
Hello sirnoname,
Could you please tell me how to purchase Extractor? :P
yuquanhai
Postby yuquanhai » Mon 14. Aug 2017, 05:34
Hello TheStick,
Could you please tell me how to purchase Extractor? :D
yuquanhai
