Extractor connexion problem  Topic is solved solved with post #21111
Postby TomKlash » Tue 21. Mar 2017, 08:34
For witch reason i have this always this panel when i change of game, plug-in or download new plug-in ?
Thanks a lot.
TomKlash
Images: 40
Re: Extractor connexion problem  Topic is solved
Postby sirnoname » Tue 21. Mar 2017, 09:02
As told you in the box, you have network problems. Maybe IP Range.
Postby TomKlash » Tue 21. Mar 2017, 09:53
I must change my IP adress ? I've an fixed IP given by my router (box).
Envoyé de mon FRD-L09 en utilisant Tapatalk
TomKlash
Images: 40
Postby sirnoname » Wed 22. Mar 2017, 01:57
Check firewall, IP range and the ip in the converter top right. Maybe you are loading a profile and you did not change the ip inside the profile (settings-> cluster in extractor).
Postby TomKlash » Wed 22. Mar 2017, 08:46
Ok i'm going to test this.
TomKlash
Images: 40
