Extractor override for profile name issue.
Postby motiondave » Sat 25. Aug 2012, 11:31
This is best used with 2 screens or 2 separate pcs.
Find the game exe you want to play and copy/paste the shortcut to the desktop.
Set up the game exe and plug in as per instructions in the extractor.
To start a game, double click the game exe on the desktop
select the game from the list in extractor, then click "try to send data",
then click start on the converter , and hopefully , you should have motion without having to re-write the profile description.
Yes , it is a bit of mucking around, but until the extractor profile naming thing gets fixed, this will allow you to play a game.
