save profile  Topic is solved solved with post #18869
save profile
Postby kappacina » Wed 24. Feb 2016, 23:02
Hi.i'm Denisi have a problem.when i save a setup in converte everything work ok but if i change any value And save a new setup when i relaunch the game te simulator go All to the right or to the left And i reload old origine And everithing work too.why?
kappacina
Re: save profile
Postby sirnoname » Thu 25. Feb 2016, 08:46
because of your changed value
Re: save profile
Postby kappacina » Thu 25. Feb 2016, 11:30
Thank Sirnoname!But i don't understand because when i changed value while i play game for fine tuning everything works fine but if i close the game and then re launch with new save value simulator go crazy.go forward for 3/4 second and then turn all the left or all the right and i stop engine or crash to the real ground :-).If i load the old profile everything work again. I dont understand because new setting before work and when i save and relaunch the game no. :-(
kappacina
Re: save profile  Topic is solved
Postby vicpopo » Thu 25. Feb 2016, 22:10
Because the profile linked from extractor to converter is always the old one.
If you don't want to rename the new profile in converter with your new settings , you have to go to extractor ( converter still open ) and right click in the plugin game window and update the profile with the current settings.After a window appears and says that is a there a profile open in converter .Click yes and after that when the next time you open extractor and converter you will have the right profile from converter with changed values.
Re: save profile
Postby sirnoname » Fri 26. Feb 2016, 00:38
Yes, the extractor has a copy of the rn2 file and push it.
Re: save profile
Postby kappacina » Fri 26. Feb 2016, 10:47
Thanks thanks thanks a lot!!
kappacina
Re: save profile
Thanks thanks thanks a lot!!Now works perfectly!!
kappacina
