Set ups inquiry helps
Postby Kool7789 » Fri 7. Aug 2015, 17:41
Dear Moderator & Experts,
I had set up the motion extractor and Motion converter for iRacing and its very good.
I wonder to ask do i have to do the same procedure for my the others games like AC and Race On?
Hpe can get a answer soon.
Many thanks in Advance,i really need your help
Kool7789
Re: Set ups inquiry helps
Postby TheXRacer » Fri 7. Aug 2015, 18:24
Good Day Kool,
yes ....you control and check the axes/ ge-forces .....also
reflect the axes or changes the decisive factor .... actually remains at your profile equal ;)
It´s easy to learn ....but very time consuming
best regards
Chris
TheXRacer
Images: 9
Has thanked: 5 times
Postby Kool7789 » Fri 14. Aug 2015, 10:31
Thanks Chris. I will go and have a try.
Thanks for the info
Kool7789
