Extractor problems (not detected)
Postby dynamixxbe » Tue 21. Apr 2015, 15:55
Hello,
I'm experiencing some weird troubles with the latest version of X-Sim (downloaded on 17/04/2015).
When trying to run either Assetto Corsa or iRacing from the extractor menu, the profile I created for the game runs for about 5 seconds and then automatically stops. When I try to start the simulator in the converter screen, after pressing 'play game' in the extractor, it says the Extractor was not detected or not running, while it's opened and visible in the tray. The simulator however runs for 4 - 5 seconds, until the game boots, and then stops, just like the profile in the Extractor.
Even if I continue to let the game launch and start a race, it says 'game detected' but then gives an error that no profile was created for the game (Extractor: missing). It then says to press the '...' button in the Motion driver, but when doing so it just says that no profile was found for this executable and that I need to insert some profiles into the local database. However, I created a profile right before launching the game...
I have been looking for a solution for quite some hours and have tried several suggestions like run as Administrator, firewall disabling but nothing works.
I have also followed SirNoName's youtube training video, but also with no success.
Also, since X-Sim was never installed on this computer before, it should not be because of some faulty left-over files or registry keys from previous versions.
The specs of the pc: Windows 7 Ultimate, i7 950 CPU, 12 GB Ram, AMD Radeon R9 200 Series GPU.
I attached a couple of pictures from the various errors and hope this could help someone in finding a solution to this problem.
Thanks in advance.
Profile error in motion driver after Assetto Corsa was stopped by X-Sim
Second window in Assetto Corsa when starting race
First window in Assetto Corsa when starting a race
Error from convertor window when pressing START after Play game is pressed in Extractor windows
Extractor screen when profile stops automatically
Extractor screen right after clicking 'play game'
Extractor screen before running game
dynamixxbe
Re: Extractor problems (not detected)
Postby dynamixxbe » Thu 23. Apr 2015, 13:35
Hello,
This problem is now solved thanks to the newer assetto corsa plugin found on the forum here :)
The problem with iRacing was fixed by reinstalling X-Sim.
dynamixxbe
