Windows 8.1
Windows 8.1
Postby Erwan960 » Wed 25. Sep 2013, 10:46
Hi!
I installed Windows 8.1 Pro x64 this morning and I also reinstalled x-sim.
The problem is X-Sim Converter works fine whereas X-Sim Extractor doesn't launch anymore. I tried to launch with compatibility (windows 8, windows 7, windows vista...) without success... It is now impossible to use my simulator. Did anybody faced with the same problem?
Thanks !
Erwan
Erwan960
Re: Windows 8.1
Postby sirnoname » Wed 25. Sep 2013, 15:49
This bug will be solved in 3.0.2.6. I think to make a update this evening.
Re: Windows 8.1
Postby Erwan960 » Wed 25. Sep 2013, 17:18
You are the man ! :D
Another note: with windows 8, when we close x-sim (controler and extractor) it always has an error that requires a closure program rather brutal way.
Erwan960
Re: Windows 8.1
Postby sirnoname » Wed 25. Sep 2013, 19:23
I heard from it but I do not have the same problem.
Maybe someone can test this with a virtual machine which we can share?
No computer on my side has this problem. No windows version either.
