cheat engine to extractor HELP
Postby caiubbo84 » Sun 10. Jun 2012, 19:23
Hi to all,
this is what i found with CE,
how to setup in DMA in the extractor?
regards
caiubbo84
Images: 15
Re: cheat engine to extractor HELP
Postby sirnoname » Sun 10. Jun 2012, 23:54
You need to enable the memory driver and then you have to read the manual where you have to set the pointers.
Postby caiubbo84 » Mon 11. Jun 2012, 12:42
Hi sirnoname
The problem is what i need to write in the dma if you see the picture what is the base pointer and the ofsets aren't complete! Can you do a screenshot whit dma compeled whit my values? Thanks
Is a week that i'm stopped for this!
caiubbo84
Images: 15
Postby tronicgr » Mon 11. Jun 2012, 19:24
Did you read the manual? It shows how to do it:
http://www.x-sim.de/manual/tutorial.html
Postby caiubbo84 » Mon 11. Jun 2012, 21:31
Hi Thanos,
Yes i did but if i do what in the manual is written , in the extractor i don't have the value! So if anyone can post an example with my values posted, i think that i jump something!
Thanks for help,
Best regards
Valentino
caiubbo84
Images: 15
Postby sirnoname » Wed 13. Jun 2012, 16:43
This view is not what you have to find with the cheat engine.
For example the last fva.exe offset is not possible in X-Sim and do not make sense.
You can only enter numbers.
Do you have a explanation for that entry?
Postby caiubbo84 » Sat 16. Jun 2012, 14:12
hi sirnoname,
i now that only addresses are allowed fva.exe is a dinamic address i found the static address that generate fva.exe, found speed and gear value, all work with extractor now! now from speed i've calculated the longitudinal force but when i drive reverse gear the longitudinal is positive for the speed, so i think to find the real force but is to strong to do, any suggestion? the problem is that the game don't have a pause menu, only back to box when i press exe!
thanks
Valentino
caiubbo84
Images: 15
Postby caiubbo84 » Sat 16. Jun 2012, 14:56
NEWS
Found real longitudinal!! i am very happy now i need only the lateral and my work is completed!
Any tips for lateral? in memory!! not forcefeedback! ;)
caiubbo84
Images: 15
Postby sirnoname » Sat 16. Jun 2012, 15:07
If you found the structure it is the next value in the memory ;)
Postby caiubbo84 » Sat 16. Jun 2012, 18:39
hi sirnoname!!
you are right it was there! i found it now i can test all on my structure! now i'm very happy that i learned this, and i found a very fast metod to find the offsetts!
Thanks!!!
caiubbo84
Images: 15
