Login problem / Internet problem!  Topic is solved solved with post #17465
Re: Login problem / Internet problem!
Postby DHWWG » Mon 28. Sep 2015, 20:40
Hello,
first I uninstalled KB3081455 ---- same Problem no Connection with Extractor
next I uninstalled KB3087040 --- Extractor Connection available. - please try
DHWWG
Postby spyderwash » Mon 28. Sep 2015, 21:34
I have the same problem on 2 pc but all without update believe it is due to explorer, x-sim is authentic only explore or others like firefox?
spyderwash
Postby rdjango » Mon 28. Sep 2015, 22:30
Hello,
thats it - update KB3087040 ist the reason. After uninstalling I can login.
rdjango
Postby sirnoname » Mon 28. Sep 2015, 23:25
Windows 7 does not have this update, it is 10 related.
I check if I can install somewhere W10.
Postby jnikitas » Tue 29. Sep 2015, 13:16
El problema es la actualizacion de windows, desinstalenla!
jnikitas
Postby sikjar » Tue 29. Sep 2015, 17:19
I also uninstalled KB3087040 from Windows 10, now Extractor is working!
sikjar
Postby salvatoretop » Tue 29. Sep 2015, 20:00
Salve ragazzi..... stesso problema non riesco ad entrare...... per favore kevin te che sei italiano e ci capiamo meglio mi spieghi per favore? Cosa è questo registro...... io sono impedito! Grazie anticipatamente
salvatoretop
Postby sirnoname » Tue 29. Sep 2015, 20:07
What is your windows version?
Postby salvatoretop » Tue 29. Sep 2015, 20:14
Windows 7
salvatoretop
Postby sirnoname » Wed 30. Sep 2015, 00:09
I have installed W10 with all updates including KB3087040.
No Problem with login here.
