Login problem / Internet problem!  Topic is solved solved with post #17465
Re: Login problem / Internet problem!
Postby lyspatriote » Sun 27. Sep 2015, 21:25
do i have to write someting in welcome as well?
i try all the trick you sugest, still stuck, i have the offline code, but i cannot connect
still trying
lyspatriote
Postby lyspatriote » Sun 27. Sep 2015, 21:40
Is that what everybody see here
lyspatriote
Postby lyspatriote » Sun 27. Sep 2015, 21:54
Maybe dumb question but what is '' X-Sim Registry Cleaner ''
i download a registry cleaner software cleanmyPC is tha t what you are talking about? i have the offline code as well not able to log
lyspatriote
Postby lyspatriote » Sun 27. Sep 2015, 22:06
ok got it
i unplug the network wire from my pc
so i could ennable the offline mode and it work
lyspatriote
Postby sirnoname » Sun 27. Sep 2015, 23:47
I will do some tests next week, but on my side it works what make this difficult.
How about some beta testers for next week to find a solution?
Postby sirnoname » Sun 27. Sep 2015, 23:48
The registry cleaner is also executed in the last step of a x-sim installation (checkbox).
Postby sikjar » Mon 28. Sep 2015, 07:27
I have no experience with beta testing, but would love to help. Just let me know what needs to be done.
sikjar
Postby sirnoname » Mon 28. Sep 2015, 18:02
One more person with that problems and we can start.
First I need your Update history of last thurthday. Go Windows updates and find the microsoft update "installed updates" dialog.
Add row Update ID and date to get more firm with last week.
Postby DHWWG » Mon 28. Sep 2015, 18:31
Hello Sirnoname,
this is my update history since last thursday. Also no experience with beta testing, but try to help.
DHWWG
Postby sirnoname » Mon 28. Sep 2015, 18:46
Same patches for both of you?
What happens if you temporally remove the komulative patch (has an IE patch inside). You can install it again after it is removed.
