Extractor hung since win10 creator update  Topic is solved solved with post #22192
Re: Extractor hung since win10 creator update
Postby ahmed » Fri 2. Mar 2018, 02:05
i need the solution please the extractor stuck at get last profile run last plugin
ahmed
Postby sirnoname » Fri 2. Mar 2018, 08:41
Give all exe files admin rights in compatibility mode tab or install to your documents. It is only limited access in W10.
Postby howcanea » Thu 29. Mar 2018, 10:08
How to turn those effort down with all of these updates
howcanea
Postby asticher » Thu 21. Jun 2018, 14:24
Problem is still not solved for some Plugins.
If LockOn or the DCS Plugin is used the Extractor start only once.
After rebooting it hung @ "Get last profil".
After clearing profil (no plugin used) the extrator runs perfekt.
Install in C:\Users\xxx\X-Sim\ won´t change anything.
Also deleted all other plugins und wizard scripts, no solution.
Admin rights are set on all x-sim files.
Testet on Win10 with Fall and Spring Update.
Without the win10 updates the extractor works - but this is Dead End.
"No Brain, No Pain"
asticher
Images: 20
