Login problem / Internet problem!  Topic is solved solved with post #17465
Re: Login problem / Internet problem!
Postby sirnoname » Fri 25. Sep 2015, 00:57
https://support.microsoft.com/en-us/kb/282402
set max connections to 10 or 20 and try again ...
Tell us the result.
Postby lyspatriote » Sat 26. Sep 2015, 05:23
same problem here ,on win 7, log ok with all browsers to the forum, will try your idea, good luck everybody
lyspatriote
Postby lyspatriote » Sat 26. Sep 2015, 05:36
i try you idea in registry ad 10 to Maxconnections, follow the instruction on your link, no chance so far
lyspatriote
Postby sirnoname » Sat 26. Sep 2015, 09:18
How about if you try to login about 10 times? Does it work 1 of 10?
Postby sikjar » Sat 26. Sep 2015, 14:24
I have tried the above suggestions also, but the Extractor fails to load every time. It seems to fail at different points, sometimes I get a prompt to enter user name and password and then the 'Login problem' message appears, other times the 'Login problem' message appears as soon as the program opens. But it appears every single time. I am running Internet Explorer 11 on Windows 10, connecting from China via a VPN.
sikjar
Postby kevin123 » Sat 26. Sep 2015, 15:19
It is happening to many people this login problem .. to me that I have the offline version.
I reinstalled x-sim and gives me this problem logging in, what is the solution?
kevin123
Images: 132
Has thanked: 15 times
Been thanked: 11 times
Postby sirnoname » Sat 26. Sep 2015, 15:54
Did you enable the offline mode in settings?
Postby sirnoname » Sat 26. Sep 2015, 15:56
I know the problems from china, however the forum is not available from my position 1 of 10 times in internet explorer.
With Firefox it seems to be OK.
What is your result if you open 10 internet explorer with forum login?
Postby lyspatriote » Sat 26. Sep 2015, 16:49
0 in 10 sorry
im log in forum with firefox, chrome, explorer
from canada
is this problem affect all x-sim user? or just a small groupe of unlucky ?
thanks
lyspatriote
Postby kevin123 » Sat 26. Sep 2015, 17:18
sirnoname wrote:Did you enable the offline mode in settings?
Hello.
The problem is that, when I start extractor tells me to login, insert user name and password and I get the message "login problem" and then closes all .. so I can not put the key offline.
kevin123
Images: 132
