cheat engine to extractor HELP
Re: cheat engine to extractor HELP
Postby hraanan » Wed 7. Aug 2013, 23:07
I have now the same problem how to get the addresses and offset from cheat engine to the x sim.
I have base address "Falcon BMS.exe"+00A144C8" and 4 more offsets... I try to put 00A144C8 as base but I get nothing.
I can't use the address of falcon because it's change every time I open the game.
So, is there anyone ים' can explain me how to put it in x-sim?
hraanan
hraanan
Images: 12
Postby crs2012 » Thu 8. Aug 2013, 01:31
http://www.x-sim.de/manual/tutorial.html
trial and error.
You haven't found the true static value yet. If it changes each time after reboot, you know you have the wrong value.
Try finding something simple that you can verify with on screen value in game... Like with a race game, you can see the MPH or Gear #.Then work on finding the more complex values like long and lat using the same methods.
crs2012
Images: 61
Postby caiubbo84 » Thu 8. Aug 2013, 09:45
This is an anti-cheat method, so uou need to find the pointer of FalconBMS.exe, probaly you find a process windows that is static but only for your pc. If you have windows 8 than you can forghet to use this method, the memory is completly dynamic. Good work and fun!
caiubbo84
Images: 15
