Converter quit! Please Help
Postby GearHead » Tue 10. Apr 2012, 04:06
3.0 Converter crashed on me and would not not restart, I have redownloaded and reinstalled it twice and can not get it to run anymore!? when starting the program I get the spinning circle to go...then "Program has stopped working" error Any ideas?
GearHead
Re: Converter quit! Please Help
Postby RafBR » Tue 10. Apr 2012, 06:38
Use the RegistryCleaner tool located in the x-sim/otherstuff folder. For sure it will work.
regards,
Rafael.
RafBR
Images: 24
Postby sirnoname » Tue 10. Apr 2012, 14:01
I would like to have the defect registry for my reference.
Can you open the registry editor and export the HKLM/Software/X-Sim Path?
Postby sirnoname » Wed 11. Apr 2012, 16:36
Changed in 3.0.0.1
Postby abratop » Wed 2. May 2012, 14:00
Hello, I had the same problem with the latest version, clean the registry, reinstalling everything and was still failing and I remembered the last thing I install on Windows 7, which was to link mobile phone to bluetooth device, unlink the phone and I start the converter.
abratop
Postby motiondave » Wed 2. May 2012, 14:19
abratop wrote:Hello, I had the same problem with the latest version, clean the registry, reinstalling everything and was still failing and I remembered the last thing I install on Windows 7, which was to link mobile phone to bluetooth device, unlink the phone and I start the converter.
as long as it works now
Postby abratop » Wed 2. May 2012, 14:22
yes, if it works perfectly
abratop
Postby sirnoname » Wed 2. May 2012, 19:55
bluetooth problem solved in 3.0.0.4.
Have seen the same problem, was casued by the virtual comport of bluetooth which does block a communication instead of returning.
The interesting thing is, this bug was not detected until *
Update will be online i think in a few hours with some special addon for your phone ;)
